EGR question
Old 10-01-2007, 01:38 PM
danielgoforth's Avatar
Default EGR question
Hi there, i've got a 99 trans am ls1 into a jeep wrangler, and was wondering if there was any downside to blocking off the egr stuff (besides smog). I have long tube headers w/ the egr outlets, but none of the other parts. Can't i just block off all the holes and put a plate on the intake manifold inlet? I was thinking it might be easier than buying the needed parts. Thanks!
Danny
Old 10-01-2007, 03:45 PM
pinesol_hater's Avatar
You should be able to just remove it and block everything off. You'll probably throw a code because of it but I'm guessing with a project like yours that won't be the only one, get a tune, have the code removed.
Check the sticky for more info on this stuff.
An LS1 in a Jeep sounds sick, good luck man!
Old 10-01-2007, 03:50 PM
TheLS1Kid's Avatar
A bunch of guys on here including myself block off the EGR.
I would cut the EGR provisions off the headers completely, then just get the hole welded up.
Old 10-01-2007, 08:19 PM
SSsuperdave's Avatar
I blocked mine off and bought a LS6 intake. Worked fine
