Max mm throttle body mod
Old 10-07-2007, 08:36 PM
chrismorales75's Avatar
Default Max mm throttle body mod
How big can you port a stock throttle body to?
If you are not running coolant through the stock throttle body can't you just port it out and install a bigger throttle blade?
Has any one done this and what is the biggest size you can run on a stock LS1 intake?
I know that machining it out and making a new throttle plate would be cheaper than an after market throttle body, so who has done it?
Old 10-07-2007, 09:05 PM
shoemike's Avatar
you could go as far out as the inlet of the intake will allow, what ever that is.
i think 80mm TBs need a spacer so you probably can`t go to far.
