e fan problems
e fan problems
I got my new/temp computer from Jared at Current performance wiring. Tune works great after a little adjustment of the IAC and throttle plate. take it for a test drive, the fans seem to be working. Everything appears to be sound. I go to the store and it is running hot, pull over and the fans just came on (200/210degrees). I drive home fans did not come on at all. I test my fans, appear to be dead. I swap them out for some flex a lite 220s. Hook them up, and let idle to about 190-195, they dont come on. So,I tested the wires from the harness with a test light, the red wire is hot, and the black wire is hot as well. Any suggestions?
