Fst Toys 85mm Lid and Delphi 85mm MAF??
I tried to mock up my new setup this weekand ran into a little issue.
the adapter for the Delphi 85mm MAF accepts both the IAT sensor and the smaller MAF plug and combines them into one 5 pin connector.
BUT, the Fast Toys Lid has a hole for the IAT sensor already drilled.
My question is, why?? If the Delphi MAF combiines both the MAF and IAT sensors, why is there a hole drilled in the lid for the IAT??
Can you get the Fast Toys Lid without the hole predrilled??
Thanks
Tony
Thanks
Tony
You can special order it without the hole but we don't normally stock them that way. We hold you order until our next batch is produced and then have one made without the hole.
Otherwise, you can just plug the hole if you want a lid quicker.
