Ls6 Intake Install Questions
Ok plan on installing a ls6 intake off of a 02 ss on to my 99z other than the crossover ls6 tube is there anything les i need to install when i switch it out? i have heard about replacing the oil pressure sending unit and the knock sensors ? should i go ahead and replace these when i do the intake swap? I also plan on installing a catch can sometime soon.......let me know people thanks to all !
this thread is a little old but I have a question.
when your doing the install do you just leave all the coolant tubes and plugs alone if you've grinded the ribs on the ls6 intake? I shouldn't have to mess with those tubes at all if I grind down the ribs?? also, if I grind down the ribs and leave the foam padding on there will I then have to mess with the coolant tubes?? TIA
