Who has an Alternator Overdrive Pulley?
Restricted User
I'm looking for one to correct a charging problem I've been having since installing my ASP U/D pulley. If you have one, where did you get it from and how much was it. Also, how did you pull the stock pulley off and press the new one on?
http://www.ws6project.com/user_stor/...d13765b9acf7ed
its not pressed on. you use an impact to remove the nut. after you get the nut off the pulley comes right off. you put the new pulley on, put the old nut on, and impact the nut back down.
Restricted User
Okay, I was wondering about that. I bought the same pulley from the link but it's center doesn't look like it would fit at all over the alternator shaft. I'll give it a go. Also, the one from the WS6 store is bigger than the stocker. Shouldn't an overdrive pulley for a 'driven' gear be smaller than stock?
