Simple Wideband ???? but can't find my answer??
Old 11-28-2007, 09:43 PM
yellowjacket48's Avatar
Default Simple Wideband ???? but can't find my answer??
I searched and searched to find the answer to my question, but no luck. Do I need a wideband if I'm not going to run nitrous? Will it help me tune my car once I install the cam?
Old 11-29-2007, 08:23 AM
radkon's Avatar
A wideband is needed to safely tune PE (power enrichment) also known as WOT (wide open throttle). I wouldn't try to tune PE without it.
You can tune part throttle without a wideband by using LTFT (long term fuel trims) and get close. I was within 2% after many, many hours of tuning but if I had to do it over again I'd start with the wideband. Makes things much faster and easier.
BTW: Nice car check out LS1gto.com for more GTO specifics.
