Used fast 78mm intake for $400-$450 ok??
If i can pick up a used fast lsx intake for around $400-$450.00, Is it woth it & should i get it ? currently i am running ls6 intake on 04 gto.
The 78 MM FAST and 90 MM fast are only about 3~5 HP different according to research Tony has done so if you can pick up a 78 cheap I'd go for it. I did! I gained 10 HP from the swap.
