Disable the converter lock-up
Old 07-02-2003, 10:47 AM
98Raptor's Avatar
Default Disable the converter lock-up
GM High-Tech Performance
The Final Countdown
“As for the second area of opportunity, eliminating converter lock-up… TGOW launches hard and rockets though First and Second gear, but noses over dramatically midway through Third with lockup, dumping about 300 rpm in the process… This explains the weak trap speed relative to ET and could possibly account for a tenth or more in lost ET. It’s nothing $10 and a trip to Radio Shack can’t cure, namely an inline switch to disable the converter lock-up, and a 15-ohm resister to trick the computer into thinking the solenoid is engaged.”
Does anyone know how to do this? I am pretty sure I am having the same problem.
98 TA
Best ¼ ET: 13.03@104.11
98Raptor is offline
Old 07-02-2003, 11:25 AM
WILWAXU's Avatar
Default Re: Disable the converter lock-up
Umm.. spamming every section of the board isn't going to get your question answered faster....
Locked - no External Engine content.
WILWAXU is offline
