Do LS1 intakes have no EGR???
Old 01-09-2008, 12:11 AM
tnmotown's Avatar
Default Do LS1 intakes have no EGR???
Just curious, if the intake manifold has no EGR, does that mean its an LS6 manifold? Or is there some LS1 manifold that dont have EGR? just curious because if i go to a wrecking yard and check them out. thanks for any input
Old 01-09-2008, 12:13 AM
tnmotown's Avatar
forgot to mention, the guy at the wrecking yard says he has manifold that came off a 2000 and 2001 corvette?
Old 01-09-2008, 04:52 AM
green28's Avatar
Don't quote me, but I think LS1 manifolds that came on Corvettes did not have EGR, therefore from the top looked the same as an LS6 intake. If its a 2001 then it will for sure be an LS6 intake. Best bet is to just check the parts number or look at the bottom of the intake if it is off of the motor.
Old 01-09-2008, 04:58 AM
bryan04h's Avatar
97-00 vette's had ls1 intakes w/o egr..best way to tell other than checking the part# would be to look at the bottom of the intake manifold...the ls6 intake is flat where as the ls1 intake is wavy
Old 01-09-2008, 09:12 AM
tnmotown's Avatar
they gave me the part number, here it is PN# 12556333
Where do i go to check the part numbers out?
Old 01-09-2008, 09:21 AM
99FormulaM6's Avatar
thats a LS1 intake. Just do a search here of that number and you get a bunch of results
