Bad coil pack......What are the symptoms....................
LS1Tech Administrator
Received 1,794 Likes
Re: Bad coil pack......What are the symptoms....................
If you have stock tuning and a coil pack goes bad, you should get a P0300 code and (one of the following) P0301 to P0108. Those are misfire codes and you would be getting them if the pack was not firing so long as you have not turned those codes off with custom tuning.
