MAF Location ??????
Old 01-13-2008, 10:37 AM
popeye's Avatar
Default MAF Location ??????
I am transplanting a 5.3 from a 2003 Yukon and I need to know where the best place would be to install the maf.
I was thinking about the inner fender and install a K&N filter directly to the maf ??? or I could install it close to the radiator if needed. This is the only location I can think of. Does anybody have any suggestions??
Thanks
Old 01-13-2008, 11:37 AM
12secSS's Avatar
You want a striaght piece of intake tract prior to the MAF, to avoid inconsistent airflow readings. Having said that, I would go with the inner fender, but the filter mounted at least 6" ahead of it.
Old 01-13-2008, 05:04 PM
popeye's Avatar
Can I attach the maf directly to the 90 elbow?
Old 01-13-2008, 11:18 PM
03chevy5.3rcsb's Avatar
not true, my filter is basically attached to my MAF,same as all trucks, but inner fender is prob. where the harness connector is located in that area
