Slp Loudmouth 2
Slp Loudmouth 2
i have the slp lm2 on my car but the tips are hanging low. i looked under the car and the bracket on the passenger side that bolts to the pipe keeps sliding out of the graument(or whatever) on the car. i hope you guys understand what im trying to explain. have any of you loudmouth owners had this problem or know how i can fix it?
If I understand you correct,use two small hose clamps on each side of the rubber hanger.Tighten the clamps on the exhaust brackets that go into the rubber hangers or you can use zip ties but then you need to cut to remove.
