59cc heads W/ Ms4?
Old 02-12-2008, 01:11 AM
1evilss's Avatar
Default 59cc heads W/ Ms4?
Hey guys Im looking to get a magic stick 4 cam, but I dont know if I will have enough clearance with my heads. My heads are Ls6 heads Milled to 59cc with other port work done to them. Anyone running anything close to this?
Thanks
Ronnie
Old 02-12-2008, 09:41 AM
lilbuddy1587's Avatar
NO
You need to measure and flycut the pistons (if necessary) if you're planning on running ANY type of milled/large valved heads with ANY cam.
Old 02-12-2008, 09:49 AM
buddha845's Avatar
Originally Posted by lilbuddy1587
NO
lol i pictured the cat in your avatar screaming that
but hes right. if you have to ask you should probably measure
Old 02-12-2008, 09:53 AM
bjamick's Avatar
No doubt about it you will have to flycut and alot at that. If you dont there will alot of noise on first startup along with alot of bent valves and prob spun rod bearings .
Old 02-12-2008, 09:54 AM
blksheep's Avatar
+1 you should measure.... and shouldn't this be in internal???
Old 02-12-2008, 04:06 PM
1evilss's Avatar
Thanks guys...I currently have a cam but its not as large as the MS4. My current cam is only 580ish on the lift. with a 240 duration. Im gonna measure it but was debating on going bigger and did not want to buy another cam and it not workout.
Old 02-12-2008, 05:23 PM
98RedBird's Avatar
I just bought the MS4 and have PRC 5.3 2.5's milled to 59cc. Clearance is not even close. You need to flycut. I was told by TSP to go .100" on both the intake and exhaust if that helps.
