plugs
Old 02-12-2008, 03:57 PM
discostu's Avatar
Default plugs
this was my first time doing plugs on an ls1. all i can say is damn it took me just under 2 hours to do plugs. is it me or did that take to long.
Old 02-12-2008, 04:51 PM
2001NBMZ28's Avatar
That's not bad for the first time, sure you can do it quicker now. First time I did the drivers side one day, then waited to do the passenger side the next. Removing the air pipe and sliding the coil pack up helped a lot.
Old 02-12-2008, 06:06 PM
iamsickofitall's Avatar
that's right on par with a first time plug change...i can do mine in under 30 minutes now.
of course i did remove my AIR system and only have two coil pack bracket bolts in place so it is much easier to reach. i also found the right ratchet/extension/socket combination to get the job done quicker
