Sound clip and exhaust set up help.
I currently have LTs with an ORY into a 3" Flowmaster single in dual out, and not cats. I was thinking the other day about keeping the first part of my set-up, but instead of the Flowmaster getting a Magnaflow bullet and in front of that doing a cutout. Anyone ever done something similar to this and know if it will all fit? Or if it will improve performance?
Also I'm looking for a sound clip of something similar.
The magnaflow bullet and E-cutout will fit between the end of the y-pipe to where you go over the axle. Problem is, the cutout will sit way toooo low and it will scrape! So you can go with the cutout but the bullet muffler would somehow have to be mounted after the axle where you see my single in dual out magnaflow. Otherwise you will have to do the cutout right under your rear seat (fits perfectly) and just do a normal catback setup like mine.
