EGR&AIR removal
Im not sure about the EGR but the AIR removal was pretty straight forward. Just remove the pump under the drivers headlight and pull out the tubing to the manifolds. Just make sure you pick up some block off plates.
trust me its not that complicated that u will need pics i did mine with out pics in about 30 mins, just remove the air pump under the drivers side headlight and the air hoses to the manifolds, get the block off plates and some silicon for the egr electical plug and air plug
