can a fast78 be upgraded to a 90mm
Correct. You just need to buy the upper shell. I would recommend buying the gasket as well. It's a straight forward procedure; simply remove the intake bolts holding the two pieces together, gently pry the upper shell away and replace. It will take some pressure to seat the new gasket.
Have you converted one of the fast78s your self Drkphx? pm me a ppicture of your black transam with the y2k wheels also if you don't mind I have been thinking about getting a set for my T.A.
