Typhoon Intake manifold!? Coolant line?
When these first came out, they had some issues with sealing at the intake ports. They have since came out with a better(thicker) gasket which stopped the leaks. The coolant lines don't come with the intake and have nothing to do with it. The intake is high enough off the valley cover to be able to use any of the factory coolant lines. If you get one of these intakes, just make sure you use teflon tape on ANY pipe threads so you don't have fuel leaks.
