Tie-downs as opposed to poly bushings?
Reading some posts here about rattling, etc... and notice the mounts must be crap or something since people install poly and all ills go away. I also read it is PITA to do. So back when I had a Buick before poly mounts was around we used ratcheting tie-downs. It won't fit a sag problem but from what it looks like that isn't the problem here. It seems the motor/exhaust is lifting so wouldn't this be a cheap and easy alternative?
I can get it for you, have to order it. Might be in stock here though... Same price as I would get it for
http://www.ls1speed.com/catagory.cfm...%20/%20Chassis
