Buying Used 6.0L Truck Engine...Questions?
The engine is supossedly a 2004 6.0L w/100K miles from a 2500HD. Is there a certain casting number that should be on the heads or block so I can make sure its a 6.0L. Also what should I look for when looking inside the block as I want to make sure there are no spun bearings. Thanks, Brad
