How much better are the 241's over the 853's
Stock for stock the 241's will give you a few more hp, but not enough to warrant the expense. When you start porting they're the same head. A simple port polish on the 853's will make them equal to the 241's.
Find some 243s if you want to swap stock heads on...they'll give you a decent increase and can sometimes be found for cheap.
I've seen a few pop up every now and then for $250 with low miles.
