Help me.(12 volt wire) manual fan switch ls1
Old 08-28-2008, 08:48 PM
Pete_Dragoon's Avatar
Default Help me.(12 volt wire) manual fan switch ls1
hello i bought a very similiar like the slp. Everything i understand but i can't find a 12 volt line. I c the cd player one but i can't find a tool to get off the bolts. The one i was using broke. Those little bolts that hold the ac switches and cd player. I want to splice into the cig one but i can't find a way to take it off to access the switch.
Name what you used for the 12 volt requirment.
Thanks guys.
Old 08-28-2008, 08:59 PM
98trans-am's Avatar
if youre just looking for a 12 volt source ive used the wire after the fuse going to my wipers, ive also used the small pink power wire going to my cruise control.
Old 08-28-2008, 09:03 PM
if you have a pic that would be lovely. i dont' have a volt meter thingie tool. etc.
Old 08-28-2008, 09:07 PM
2kbluws6's Avatar
it would be a very wise investment...to add or fix anything electrical on your car....they are cheap....the orange wire on your cig lighter is +12v
Old 08-28-2008, 09:12 PM
2kbluws6's Avatar
you can pull the cubby out of the dash...the one in front of the shifter or if you have a tcs button the plate that holds the switch pops out...you can then reach the plug on the back of the lighter.
Old 08-28-2008, 09:26 PM
used cubby methods. thanks alot guys.
