Burned up my alternator at the track on friday.
Friday night I made 1 pass and right before I crossed the finish line the check gauges light came on. Alternator stopped charging. I was lucky enough to make it to my grandfathers house (23 miles) before the whole car cut out. I replaced my alternator recently due to the same issue. I'm using a reman aftermarket because at the time I couldnt afford the more expensive AC delco. What alternator have you replaced yours with and what kind of luck have you had? I believe my problem was the over-drive pulley I put on thursday. Has anyone had a problem with the over-drive pulley ruining an alternator? Or was the just a coincindence.
