Will 85m vette....
Will 85m vette Maf work on 01 fbody?
Will an 85mm 2001 corvette MAF work on my 2001 Transam?
I dont know if he has it rewired or not?
Will it work without tuning the car?
it is a DELPHI 25168491
I just looked up the stock MAF tune tables for an 01 F-body & an 01 Corvette. The MAF tables are different. For this reason, you will need a tune (MAF table re-calibration) if you want to use an 01 Corvette MAF on an 01 F-body.
The MAF table for the 01 F-body I referenced had the same MAF table as a stock 75mm MAF. So, apparently an 01 F-body used a 75mm MAF & an 01 Corvette used an 85mm MAF. Again, this is according to the stock MAF tables that I researched for you. If anyone has different info. it should be added.
For sure, if you're swapping a 75mm MAF for an 85mm MAF, you must get the MAF table re-calibrated.
