Burning oil?
Burning oil?
After my buddy did his head/cam swap and got the car tuned, he noticed blueish smoke coming out his tailpipes. Now we know its buring oil and also consumed about 1qt. of oil a month. We installed a catch can and help a little, but still does the same thing.
Now we were told it could be the rings or valve guides on the heads. How would we determine which one it could be? Is there a way to test it to see if its coming from the rings or the valve guides?
We are kinda clueless on why the car never smoked and once the head/cam and dyno-tuned was finished, it started to smoke some. Any input would be appreciate guys!
Several things need to be checked.
First - which heads? Were the guides and seals new?
second - when does it smoke - deceleration, start up or ander heavy throttle?
Third, is it running rich - who did the tune?
2nd- usually smokes after car is warmed up. Not deceleration NOR acceleration. Does tend to smoke a little during idle. Cold start up not really, but if car has been ran then let sit for 10 mins and start again, smoke will shot out.
3rd- I had it dyno-tuned by Newtech and dont think its running rich. I nailed the aif-fuel dead on
Pull your plugs and see if they have oil on them. If they are coated about a 95% it is your valve guides. Also if you didnt put any teflon tape or somesort of sealent on the rocker are bolts do that. Oil will be drawn thru there and be burnt.
