Im going to be adding some trick flow 215 heads to my car soon.... (cnc version). Was wondering if anyone out there has the 215s on their car would give let me know what kind of power they made with what cam (give cam specs plz). I am especially interested in #s from stalled a4 cars since mine is a stalled a4. Thanks!
When the time comes im gunna do TFS 215's as well. I hear there BAD-ASS. I would also like to know the answer to this, and anyones imput on how much of a PITA it is with the new rocker setup it involves.
__________________ 99 T/A Under the knife 10.9x or bust-
85 MM mas,Ram Air,Lid,Ported Fast 92/92,Fast Rails
12 bolt 3.73's,TSP 233/239,Hooker 1.75 LT's,ORY,LM1 !Egr,!Air,160 Thermo,Yank PT4000,SVO 38LB injectors. Flt Stage 5, 4' Alum DS. BMR Trakpak, LCA's,Relo brakets,Dragbar,Panhard,Subframe's, Custom loop. QA1's in all 4. 300# fronts. ARP everything,Rings,Bearings,Lifters,11:1 compression.
Old setup -11.539@ 118.82 1.649 60' 1969 z28 - 406SBC 9.77 @ 135.8 (1.413 60')
i run em numbers in sig...rockers are easy....install with supplied shims....and 7.5 pushrods...run a couple days pull a set of 2 rockers see if wipe looks fine....rebolt down and tq....run the piss out of it
__________________ 2002 EB Z06 HCI+++
60ft 1.63 60ft
1/8 mile 7.06 at 99.7
1/4 mile 10.93 at 128.25
There are plenty of numbers out there. If your cam is over 230 duration and you run a FAST manifold, you'll make 460+/410+ it seems. Some of the better combos are doing 480-500/430+ with big cams or what you'd expect from an aftermarket head (just like ETP or AFR).
One thing to note about the TFS 215, you can either have them milled to 61cc and run the GM MLS gaskets or you run a 0.040" Cometic with the stock 64cc, and you'll have enough clearance for the VRX5 or MS3 or G5X3 or similar cam. You'll have to flycut if you try to mill with a 0.040" Cometic or try to mill more than .018" (for 61cc) with that size cam. Anything smaller than ~230, and you'll be set with either the GM gaskets and 61cc or the 64cc and Cometics (I'd recommend the 64cc with Cometics - better quench with similar compression = more reliable power).
A good cam for it would be something in the 228-232 duration range with a Cometic .040" Gasket. Examples would be the TSP Torquer 2, VRX4 from Vengeance, a G5X2 from LG, F13 from Futral, or a TR230 from Thunder.
Kurtomac shows the potential with a pretty good sized cam (VRX5). Had he milled more (58cc), run a thinner gasket (Cometic .040"), and flycut to make room, he probably would have seen another ~14rwhp (0.8 point of compression is around 3%). A lot of work, but the numbers would have been right at 480.
So off-the-shelf, 450-460 should be attainable and with some work, 480 should be possible without too much heartburn.
And just something to think about, TSP Stage 2.5 5.3L heads would make very similar power - and in fact have done right around 450-460 with an MS3 (just about the same size as a VRX5) and stock FAST. Mill those heads, port the FAST, and run the thinner gasket and you'd see 480 out of those combos too.
i might go to a different dyno next week to back up the numbers and tweek a few more things in my tune...I'll keep you guys updated
thanks jake for the comments
60ft 1.63 60ft
they are bad ass, blow away my lpe 243 cnc'ed heads...all my mods in my sig...get ready to spend some &&& total cost for new top end with headers-mezier, ati...8100 not including labor..
i have the LS1 trick flow CNC 215cc heads. they are slightly touched up by Chris Frank@RayMac racing engines (ls1tech.com member NASTE_SS) to 218cc intake runner size i can remember they flow 325cfm at high lift, I think the chambers are 64cc. i haven't installed them yet, my car is M6 though. i will let you know what my car will do once the TFS 215cc heads are installed but i feel it will do like 460rwhp to 470rwhp with good tune. i recommend using roller rockers with these TFS heads, myself i will go with the 1.7 harland sharp non adjustable roller rockers.
__________________ Abdullah
2000 green M6 Z28 Mods: SLP flow pac, self ported LS1 heads with stock valves, TSP 233/239 cam, QTP 1-3/4" long tube headers, Borla cat back, ported Fast 90mm intake, NW 90mm throttle body, BMR adjustable panhard rod, BMR adjustable LCA's, BMR strut tower brace, BMR boxed SFC's, Koni Single Adjustable shocks, ES hyperflex bushings kit.
Cool. Keep us informed. You probably have another 8-10rwhp in the tune. I was thinking of the VRX5 and the TFS 215s and have been interested to see what happens with your setup... but now I'm thinking 58cc, .040" Cometics, and flycut with the Vindicator. If Ron is right and the Vindicator is worth a solid 10rwhp over the VRX5, that'd put the combo in the ~490+ range with the right tune. Btw, 58cc chambers (.036" mill) with .040" cometics and .007" piston out of the hole is right at 11.8:1 CR.
few tweeks in my tune....lean out the afr past peak tq to 13:1 try another degree or two of timing and I put some street tires on too my DR's were worn out and low pressure on the dyno....hope to hit 475 RWHP and I'll be done with my dyno racing
60ft 1.63 60ft
Trickflow heads are killer. My car just ran 9.98@138.80 with the tfs 215's on a stock bottom end 346 n/a corvette(c5).
This car is my street car driven to and from the track.
The quality and performance are top notch.
I have the trick flow 215CNC and make 447rwhp and 403rwtq through a 4400rpm stalled A4 and a Strange 12bolt. The cam specs are 234/236-646/612@114LSA and all supporting mods. Runs very low 11's and should be able to get it into the 10's with good air.
__________________ I vote for promising us big boobs and not delivering. Thats wrong in every way, kinda like driving a honda.[/quote]
