what PSI for holding valves up?
Old 09-17-2003, 09:41 AM
SSactionLs1's Avatar
Default what PSI for holding valves up?
im gonna borrow a frinds compressor for cam/valvetrain swap..what PSI is good to keep the valves up?
thanks all
Old 09-17-2003, 09:50 AM
v8maro's Avatar
Default Re: what PSI for holding valves up?
jmX on his site ls1howto.com says about 60-80psi
-Steve
Old 09-17-2003, 10:12 AM
Tally TransAm's Avatar
i used 60 no problem
Old 09-17-2003, 10:36 AM
MyLS1Hauls's Avatar
Shoot I only used 40 and you couldnt push the valve down if you tried. Remember thats 40 PSI and the intake valve has an area of 3.14 sq in. so the actual pressure pushing the valve up is 125 pounds!
