Excessive Pressure in the Crank Case..?
Old 11-09-2008, 02:13 AM
Red96TA's Avatar
Default Excessive Pressure in the Crank Case..?
I have noticed what seems to be the symptoms of excessive case pressure. I have yellowish goop on my oil fill cap, there is smoke that comes out of it after it has ran and I remove the cap, and my oil change light comes on and off continously making me think that the sensor is getting sludge/goop on it and providing a false reading (Oil was changed last week and oil meter reset).
My question however is if there is anything else that would cause these symptoms? And if not, if it is excessive pressure, what are some reasons that cause it, and what can I do about it.
The motor is getting old (117k) with mods in sig. Most done at 105k. I dont really beat on it much anymore, it sees some street races about once a month. Other than that it is just highway miles back and forth to college about once every two weeks.
It has some lifter tick, and I didnt replace the lifters with the cam, so I plan on doing that this summer, but since I found this, I may be taking the motor out for a re-ring/re-bearing now also
Old 11-09-2008, 10:11 AM
SOMbitch's Avatar
Could very possibly be blowby.
Check your PVC hoses and valve first.
There is no sensor for your oil light. It is operated from a set of calculations done by the PCM.
You may want to check your cylinder pressure.
Good luck
Old 11-09-2008, 04:35 PM
sreve's Avatar
the yellowish goop can be caused by moisture
if you short trip the car it could be condensation and it
never had a chance to evaporate it off. thats likely with
the cooler weather recently. if you do 50 miles of hiway at a time
and it comes back keep a close eye on your coolant level.
severe blowby can aeriate the oil and produce the yellow goop
also. a compression and leak down test would confirm.
Old 11-10-2008, 04:12 PM
Red96TA's Avatar
Whats going to be harmed if it is excessive pressure?
Old 11-11-2008, 11:00 AM
LS1-450's Avatar
When the oil fill cap is removed w/ the engine running, does oily air or any air blow out of the filler neck?
Quick Reply: Excessive Pressure in the Crank Case..?
