Bearing Assembly lube
Old 11-09-2008, 07:59 PM
SheldonZ28's Avatar
Default Bearing Assembly lube
Hey Everyone.
Ive been reading up on how to lube my bearings when building my engine as i will be doing so in the next couple weeks.
Most places use a SAE 30 oil. I can use this, but i thought maybe if i use some Assembly lubricant id be better off?
Im looking to know for the bearing faces (Rods & Mains) and to go on the cam journals.
Thanks!
Sheldon
Old 11-09-2008, 08:40 PM
novaflash2002's Avatar
Luberiplate 105. My dad who is a machinist has been usein that stuff since the 60's.
Old 11-09-2008, 10:49 PM
68 RS Convertible's Avatar
I use STP oil treatment for my crank and rod install's, its nice and thick. I just completed my first "LS" build, which is a 6.0 liter truck motor. I had trouble priming the oil system, until I did some research here and jacked the back of my car up to submerge the oil pump. I did a lot of cranking on my motor before I build up some oild pressure, and had no problems. I did however use assembly lube for the cam, which was the Comp Cam brand lube. Good luck!!
Old 11-09-2008, 10:58 PM
NHRAFORMULA00's Avatar
You would be better off using asembly lube such as made by torco for bearings.Just stop by an auto parts store and ask for a small tube of engine asembly lube.
Old 11-30-2008, 12:21 AM
01ssreda4's Avatar
i have heard oil is fine if crank-up will be shortly after the build. but if the motor is gonna sit a while use the thicker assembly lube.
