my cam...question
my cam...question
I have a 224/224 .563/.563 on a 110 LSA+4
and was wondering if it would respond well to nitrous or F/I better??
I'm wanting to go for lower 12s or 11s, but don't know what to do.
oh and my CR is about 10.48:1
Your compression ratio is already a bit too high for forced induction, so I'd go with N2O. Forced induction setups try to keep the CR down to 9.0-9.5 I believe, so that the boost is free to bump it up as needed through the RPM range. F/I cams usually have a bit wider exhaust duration than intake as well, from what I've seen, to help get the gases out from combustion in time for the forced air to get in and do work.
