Anybody else have this cam?
Brand: COMP Cams
Product Line: COMP Cams Xtreme Energy Camshafts
Part Type: Camshafts
Part Number: CCA-54-448-11
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,800-7,200
Intake Duration at 050 inch Lift: 238
Exhaust Duration at 050 inch Lift: 240
Duration at 050 inch Lift: 238 int./240 exh.
Advertised Intake Duration: 287
Advertised Exhaust Duration: 289
Advertised Duration: 287 int./289 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.605 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.609 in.
Valve Lift with Factory Rocker Arm Ratio: 0.605 int./0.609 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Grind Number: LS1 XER287HR-12
Quantity: Sold individually.
If so what do you think of it?
Acually it seems to pull really hard all the way up but it does have a dead spot in it around 2900rpm give or take, just curios if that was in the tune or if it was the cam?
