Just springs
Old 12-23-2008, 07:33 PM
HavATampa's Avatar
Question Just springs
Will be doing another cam swap in a few months and have about 10k on my Tea springs. Do titanium retainers and hardend seats wear? Is it safe just to replace the springs? Might do the seals while I'm in there too.
Old 12-23-2008, 07:46 PM
Shawn MacAnanny's Avatar
I wouldnt think they would wear. I'd just get a set of Viton valve seals while you're in there.
Old 12-23-2008, 08:15 PM
vettenuts's Avatar
Check the titanium retainers for wear on the underside where the spring contacts. Yes, they can wear.
Old 12-23-2008, 08:48 PM
HavATampa's Avatar
Thanks for the info. Figured I'd check seeing that a retainer cost as much as a double spring on Patriots website.
Old 12-23-2008, 09:57 PM
01ssreda4's Avatar
isn't the titanium the hardest metal in the cylinder head or no? how would it wear against an alum head and steel spring???
Old 12-24-2008, 08:29 AM
HavATampa's Avatar
Hopefully there won't be any aluminum wearing, that's what the hardend seats are for. But yeah, titanium is supposed to be harder than steel, but I imagine if the spring is machined incorrectly or some other oddity, that over time it could cause the retainer to wear incorrectly?
Old 12-24-2008, 09:50 AM
01ssreda4's Avatar
i was always told the softer metal will wear first against the harder metal. like they have solid copper or something wheel bearings in riding mower wheels. solid chunks of metal. they wear first instead of the rim and spindle then you beat em out when they are loose and hammer in new ones. the steel rim and spindle still look new after twenty years.
