Need Serious Help w/ Cam Install
I'm starting to toy with the idea of putting a cam in my car. After doing all the bolt ons i can reasonably do I just want more. My car is mostly for street use but OCCASIONAL track/stoplight racing. Which cam AND what is everything I will need for the install (i.e. timing belt etc.)
Restricted User
most guys seem to be using the 224 cams for that.....check out www.texas-speed.com they have cam kits....
that's one of the installs that really isn't that expensive by itself, but all the "while you're in there" stuff adds up quick.
Cam + lifters are a minimum in my world. Lifters belong with the cam they were originally installed with(roller or flat tappet). Only problem is that to do lifters you have to pull the heads, or at least properly. I've seen it done without.
And I thought changing lifters with the cam wasn't needed for these engines...
Ok now I have one more question: I was always told that when you replace a camshaft you ALWAYS replace the lifters. Since these are roller cams instead of flat-tappet cams how necessary is it to replace the lifters?
A lot of people do it and have no problem, to me I see it as one of those "why i'm there" safety items. Supposedly the LS7 lifters are the OEM replacement lifters for the LS1 lifters and I would do it for just piece of mind.
