Which Patriot head?
Which Patriot head?
I am haveing a TSP 228R cam installed. I have decided on putting heads on at the same time. I was going with the stage II heads, but just wondering after seeing alot of posts if I should get the 5.3 heads instead? Please help with the decision on which would make more power. Thanks
LS1Tech Premium Sponsor
Re: Which Patriot head?
You really won't beat the 5.3l heads, you already have the correct valve covers & coil brackets so why not get the 5.3l heads & get the extra compression
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
