Deluxe Heads & Camshaft Bolt & Gasket Kit and some questions....
Restricted User
http://texas-speed.com/shop/item.asp
Heads and Cam:
PRC 5.3L stage 2.5 Heads
Custom Pred-Z cam (23X/23X .61X .59X 111+2)
Ported lS6 Oil Pump
Ok so TSP has the "Deluxe Heads & Camshaft Bolt & Gasket Kit" and i want to make sure i am ording the right stuff for my H/C swap...i dont wanna order something wrong....mainly gaskets whats the best?
so heres what im getting:
ARP short and long head bolts
Graphite gasket set
ARP blancer bolt
Center bolt valve cover gaskets
LS1 valley gasket
more questions questions....
how do i know what length rod i need?
Do i need to update to lS7 lifters?
Do i need a Rollmaster Double-Roller Adjustable timing set?
Damn im gettin excited for my H/C swap but i really want to make sure its done right with the right parts.
Thanks in advance guys!
Heads and Cam:
Ported lS6 Oil Pump
Graphite gasket set
ARP blancer bolt
LS1 valley gasket
opt for the MLS gaskets, and coat them with copper gasket spray before you install them.
you dont *need* LS7 lifters, but i would
you dont *need* a adjustable timing set, but i would
and as far as PR length, the only way to tell is get a PR length checker and measure.
