just a little help please
starting a build but what is the difference in a lq4 6.0 and a lq9 6.0 and which is better or which should i go with wanting to build solid roller nitrous motor
blocks are the same as well as crank, rods, bore, stroke etc. only difference I know of is the lq4 has a dish piston to keep compression down, where the lq9 has a true flat top piston. someone please correct me if i'm wrong.
