heads for MS4
heads for MS4
hi here , i have ms4 installed in my car my pistons is Diamond flat top with -2cc valve reliefs , gasket is GM MLS , can i install patriot LS6 heads 59cc ? i want to install heads without fly-cutting the pistons
thanks
thanks
I think those heads would be fine. I was looking at a car with bout the same setup had the same pistons and a 59cc milled AFR's or somethin like that and they might have even had the TRex. They didn't fly cut
