pick up tube bolt
pick up tube bolt
Alright im in the middle of finishing my cam swap right now and i put threadlocker on the pickup tube bolt but when i go to put it in my fingers wipe most of it off when i am trying to thread it back in. is this going to be a big deal? any help would be great thanks inadvance
when we did my friends we didnt use it. You can try the thread locker that looks like a glue stick it seems a little thicker and wont wipe off as easy. im doing my cam next weekend and thats what im gunna try
also i couldnt get the pick up tube down enough to just slide the pump on so i kinda half *** had it in the pump a little bit to get the pump on but i think the o ring still seated properly cuz it had room once i got the pump on to pull the pick up tube out a bit and push it in but i was wondering if its pretty easy to get the tube pushed in wrong and chew up that o ring or if its not very likely it does that?
Well that's always good to know lol. I will be extra carefull when I do mine.
LSX Mechanic
Yep. I just did a motor swap not long ago because of that very reason. Somebody didn't seat the tube properly and cranked down the bolt anyway. It bent the bracket that the bolt sits on, and didn't seat the o-ring completely. The motor ran low on oil pressure for a while until it got the bearings...Game over.
i have one of the 1st pieces. had to grind on the part and on the cover a lil bit.
BRP has made a post since saying they have changed the design.
part of it may be due to the double roller chain.
i bought it for peace of mine.
ive got 50 pounds at idle on a ported stock pump.
I found the best way to get the tube lined up with the pump was to tighten the pickup tube bolt all the way before tightening the bolts that mount the pump. This way the pump can float/move around which allows the tube to properly align without putting it in a bind. If it gets in a bind it will damage the o-ring and you won't find out until you have it running.
I have never used any thread lock on that bolt, just did it to German Specs...goodntight. Also, if your trying to place the pick up tube back in the oil pump, you can drop the pan down a little bit to give you a bit more room.....and just make sure you dont crimp the O ring in any way. Make sure its seated properly....
