Did I buy the wrong oil pump??
Old 03-03-2009, 11:26 PM
matt94z's Avatar
Default Did I buy the wrong oil pump??
I'm finishing up gathering my cam/243 head swap parts and been thinking that I might have bought the wrong oil pump. I bought a meiling high pressure pump. Should I have bought a high volume pump instead?
Old 03-04-2009, 08:29 AM
Shawn MacAnanny's Avatar
I'm pretty sure you can change out the spring inside of pump to make it lower pressure if you wanted. You dont really want high flow on a stock pan as you can run the pan dry because the oil wont drain back as fast as you are pumping it out at high rpms. Or so people say.
