Timing chain replacement Q
Old 03-11-2009, 03:53 PM
Johnnystock's Avatar
Default Timing chain replacement Q
I did a search and found some answer but not that much.
I'm about to order my cam kit in the next week and I'm wondering if I should have a look for a new timing chain and maybe gears too.
Right now I have TR22x cam and 918 springs in my car and I dont know since when the guy had it before me. Car has 100K on the clock and I have it since 89K without issue. Pretty sure theres a good timing chain in there since my shortblock has been rebuilt, but maybe not. I'll see when I'm there.
If I have to change my timing set, what you guys recommend to me for a good price? Is a LS2 timing chain a good idea?..Cam is going to be a Torquer 3.
Old 03-11-2009, 04:05 PM
Joker98's Avatar
The LS2 set will be just fine. I've run them in two of my cam set-ups and never had a problem. Good luck with the cam..I love my Torquer2!!
Old 03-11-2009, 04:28 PM
Thanks joker98, I'll take your advice!...Yeah I really hope to have great result with the T3 and my setup!...I was hesitating for the T2 at some point But I'll go with the new grind!
Old 03-12-2009, 07:11 PM
Rob 's 73's Avatar
If you open it up you should replace the chain. Take this from someone who has broken two.
