I was in my friend's Z28 w/ the G5X-2
Old 10-20-2003, 02:37 PM
DVST8OR's Avatar
Default I was in my friend's Z28 w/ the G5X-2
First off, DAMN his car is fast . But while I was riding with him, every now and then when the rpms would come down his whole car would shutter and shake. I am not talking violent or anything but definetly noticeable. I asked what that was and he just shrugged its because I have such a big cam.
What could cause something like that? I am getting a big cam, X1, not as big as the G5X-2 but I don't want my car to shutter like his does. Is this just part of getting a big cam? Or is this something wrong?
Brian
Old 10-20-2003, 02:55 PM
jrp
SN95 Director
jrp's Avatar
Default Re: I was in my friend's Z28 w/ the G5X-2
my car does that a tad, will drop to 500 rpm or so after letting off of the gas. has his car been tuned, further tuning could probably help that.
Old 10-20-2003, 02:57 PM
Z00
Z00's Avatar
It's all in the tuning. Mine does it too with the TR227. I mail tuned it through them but it could use some more work.
Old 10-20-2003, 03:08 PM
7 Second Club
NicD's Avatar
needs tuning
Old 10-20-2003, 04:13 PM
Formerly 4mulaJoe
LS1x2's Avatar
It doesn't really matter how good you can tune. With a cam that big you are going to get that cam surge. Tuning can only do so much. Keep the rpm's up. A steeper gear will make it more driveable.
Old 10-20-2003, 06:56 PM
DVST8OR's Avatar
Yes it has been tuned by MMS. So a better tune can or can't fix this?
So that is what cam surge is?
Old 10-20-2003, 07:00 PM
7 Second Club
NicD's Avatar
Cam surge is when you are around 1000 rpm in 1st or 2nd gear and you are trying to keep it smooth but the car will want to start to "surge" or "buck" a bit at lower speeds, low RPM conditions.
It sounds like what you are describing is when he pushes in the clutch and the RPMs drop to 500. That is a tuning issue. What I mentioned above can be tuned pretty much out as well, although that will almost always be there at least a little bit with a big cam.
Old 10-20-2003, 10:12 PM
DVST8OR's Avatar
yep that is exactly when it happened
Old 10-20-2003, 10:50 PM
SSactionLs1's Avatar
i had this...i have the X1...drives great...just a MINOR surge below 1500 rpms..but she pulls to 7k like nothin
Old 10-21-2003, 12:19 AM
wicked 98z's Avatar
I had some cam surges with mine aslo. It just happens with big cams
Old 10-21-2003, 01:30 AM
Mike K.'s Avatar
You might also try messing with the idle adjustment screw. Mine was surging like above when pushing in the clutch after tuning but I was able to fix it with the screw. Now when I let push the clutch in rpms drop to about 1k and when I completely stop rpm's go to 950 which is where the pcm was set.
Old 10-21-2003, 09:13 AM
LG Motorsports's Avatar
We have worked out our tunes now to eliminate any surging with our cams. I have an even bigger cam in my car and it drives like a stock car.
Email me a copy of your ls1 edit file, and we can take a look at it.
Thanks
Lou G
Old 10-21-2003, 02:36 PM
JoSeY's Avatar
Tuning....tuning tuning....needs part throttle tuning. I have the X1 w/Stg 2 head and get NO buckin below 1500...car just wants to pull...
