Opinions on RR's?
8 Sec Tuner
Opinions on RR's?
Im interested in installing some true Roller tipped Rockers to ditch my stock ones on my X1 cammed 382. I want to keep the stock ratio of 1.7.
What rockers have worked the best?
How much will it quite the drivetrain. I kept reading sewing machine references here I now know why! I hate the way my car sounds.
Im leaning towards the Yella Terra 1.7's.
Re: Opinions on RR's?
I'm running the Yella Terra's and they are a real quality piece of equipment. Very heavy duty construction and the added plus is they fit under the stock valve covers. My setup is pretty quiet for C918's and a TR224 mot much added noise over my LS6 cam and springs setup.
I would still go with the Yella Terra's if the rest where the same price although Jessel does make quality products also. There is not much into a shaft mounted roller rocker arm and the YT design is basically bullitproof and hard to improve upon. It also fits under your stock valvecovers.
