what timing chain to get? lq4 swapped
Old 03-23-2009, 01:06 PM
nobird8991's Avatar
Default what timing chain to get? lq4 swapped
putting a lq4 block out of a denali in my car and wondering should i replace the timing chain i figure its probably best to do it so hell why not. what timing chain should i go with tho? just get a stock replacement one or is it still worthy to get a ls2 timing chain or will the lq4 one do just fine? or should i just leave that one in there it has about 100k on the motor.
Old 03-23-2009, 02:39 PM
got-a-ls1's Avatar
ls2 is what i went with... unless you want to spend big money its the best option
Old 03-23-2009, 03:59 PM
00 black ss's Avatar
i ordered the katech c5r chain. they never had one break with all the hard testing they done with it.
Old 03-24-2009, 02:31 AM
nobird8991's Avatar
now when using the ls2 timing chain what sprockets do you use?
Old 03-24-2009, 12:19 PM
sroach20's Avatar
i have an ls4 and used the ls2 chain on the stock sprockets.
Old 03-24-2009, 01:14 PM
nobird8991's Avatar
good deal thanks
Quick Reply: what timing chain to get? lq4 swapped
