Need set up advice/suggestions
guys and gals the mod bug has bitten hard and i have finally decided to add some go to the show of the 35th. I have been working with a local shop and this is the set up they have suggested.
Trickflow 215cc heads milled to spec
Trickflow pushrods
ARP Head bolts
Cometic Head gaskets
Yella Terra Ultralite rockers
Powerbond U/D pulley with belts
Ported FAST Intake
PTM 95 mm TB
Presicion 3400 converter
3.73 gears
the car currently has the TSP 228r cam with pacesetter LT's ory and rumbler exhaust. the car will be recieving a catted Y and a GMMG exhaust. Does anyone see anything that is missing or needs to maybe be adjusted? I am just trying to make sure that i get this done right the first time. the only thing i was thinking of doing different was maybe going with prc 215 heads. I am by far an expert but from what i have read they seem to perform well.
Trickflow pushrods
ARP Head bolts
Ported FAST Intake
PTM 95 mm TB
3.73 gears
The PRC 215 heads ship with the factory style valve guides. These guides will not wear out like the bronze will. So you can run the stock rockers with no issues.
