Crane Cams Dual Valve Springs drop in no head work?
will I have to machine my pockets to run these springs? Please let me know thanks and sorry for some many questions thanks agian Ronnie
I can shift faster than you.
Re: Crane Cams Dual Valve Springs drop in no head work?
Ronnie, these fit in the factory spring pocket. No modifications necessary. From the testing we have done, they seem to be excellent springs.
Jason
Jason
Super Moderator
And here is the info straight from their page:
144832-16 LS-1 Performance hydraulic roller cams
O.D. - 1.275"
I.D.1 - 0.937"
I.D.2 - 0.667"
Damper - No
Seat Pressure - 112lbs at 1.800"
Open Pressure - 352 at 1.150"
Coil Bind - 1.045
Max Net Lift w/.060" clearance - .650"
Rate (lbs./in.) - 352lbs/in
http://www.cranecams.com/springs/dual.htm
O.D. - 1.275"
I.D.1 - 0.937"
I.D.2 - 0.667"
Damper - No
Coil Bind - 1.045
