how much hp does ported polished 243 heads make.
i have a 2002 ls1 with fast intake all the bolt on's I'm fixing to do the torquer v3 cam with 3600 stall.i was wanting to buy some 243 heads while i do my cam swap.i will have them went threw and ported and polished. how much h/p will i gain from these ported polished heads? and it is on the stand now.
agreed...depends on who did the work and how good the p/p is.
budget ported 243s could only gain you 20-25hp
professional ported 243s could gain you nearly 50hp
poorly ported (fucked up) 243s could cost you power
LS1Tech Premium Sponsor
agreed with teke. You can gain 15hp bolting on a stock 243 head, 40+hp with a proven LS6 head, or who knows with a jacked port.
Checkout www.texas-speed.com we offer ls6 heads fully ported & brand new for abut 1k for the pair. Cnc work & assembly can also be done to your cores if you'd like!!
Becareful choosing a proven porter!! Spend some extra time in the dyno section looking for independent results!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Be careful choosing a proven porter!! Spend some extra time in the dyno section looking for independent results!
You might even spend some time off this forum looking for independent results.
Caveat emptor.
CARTEK Racing
I guess this is not an indipendant result but;
with CARTEK 4X [hand ported LS6 heads] and a CARTEK 4X cam, my car made 507.9RWHP, through a 12-bolt with 4.56 gears...
Fast 90/90, 1-3/4" headers and bolt ons.
