Engine Teardown Analysis and Questions (pics)
Old 03-29-2009, 04:41 PM
hyperion's Avatar
Default Engine Teardown Analysis and Questions (pics)
Hey all,
For years my car has suffered from some smoking under deceleration. In an effort to fix this I was replacing the valve stem seals when I noticed that the #7 cylinder was not holding pressure. I pulled the motor and found this:
This is a stock shortblock with AFR heads, around 10:1 SCR. Never revs past 6800. My tuner set up the car for reliability as I run at the track often. What I'm wondering is what the most likely cause is for cracking a piston like this. I'm taking delivery of a Katech 427 next month and I want to make sure this doesn't happen again.
Thanks in advance to any helpful replies!
-ch
Old 03-29-2009, 05:39 PM
conan's Avatar
That looks melted to me. Do you have a power adder? My have gone lean on a pass or 2.
Old 03-29-2009, 07:32 PM
DaveX's Avatar
That is somewhat common, and almost always #7. Don't know why though. One thing I have read that makes some sense is the possibility that the intake manifold flows slightly more air to #7, which would make this cylinder run leaner than the rest.
Old 03-30-2009, 12:33 AM
hyperion's Avatar
Thanks for the replies! No power adders, and runs on CA 91 octane pump fuel. But it's somewhat comforting (I guess) that #7 is the common failure.
Is this type of failure usually due to heat or detonation?
-ch
Old 03-30-2009, 10:20 AM
conan's Avatar
Like dave x said, it sorta common on the #7. I have read too that the the # 7 is the problem hole with running lean due to the intake design. If your 427 has forged pistons in it, you that should fix the problem.
