Texas speed 1.5?
Texas speed 1.5?
Did Texas Speed ever offer a PRC "ls6" stage 1.5 head in a 241 casting? If so, does anyone have any flow numbers or specs? I am looking at a used set, but can't seem to dig up any info on them...
Thats my problem... the heads are in the original box, but I doubt PRC ever did a 241 head and called it an LS6... So did PRC ever offer a 241 as a modded head through TS? ... sounds like the seller is either mis-informed or looking to scam...
LS1Tech Premium Sponsor
We had ported a couple of the 241 heads, they're stock LS1 heads not a LS6 head.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
When you guys did the 241's did you usually upgrade the vavles? Do you know any of the flow numbers off hand? Sorry for all the questions, just have a killer deal on a set and trying to decide if I want go this route versus a cnc'd 5.3 head...
