Head/Cam Swap...will I need new lifters? Rockers?
Old 04-03-2009, 10:22 AM
2002CamaroSS1982's Avatar
Default Head/Cam Swap...will I need new lifters? Rockers?
Hi all, I have done a search on this and haven't really been able to find a defiinitive answer to my question. I have a 2002 SS with 10,500 miles on the clock and am soon doing a head/cam swap as well as a 150 shot. The heads are Livernois Stage 3 pieces and the cam is a Livernois Stage 2 with 232/232, .595/.595 114LSA. I am just wondering what popular opinion is on changing lifters at this time, I know alot of guys are in favor of doing it because the old lifters have miles on them but this car is very low mileage.....also are stock rocker arms fine for this application? I am wanting to cut out un necessary expenses but I definitely want to do it right and not cut corners...thanks for the help!
Old 04-03-2009, 10:29 AM
greenfbodyracer's Avatar
I would replace them while your in there.. And I would get a set of roller rocker arms,
Old 04-03-2009, 10:39 AM
yyz28's Avatar
I'd change the lifters while you are there, it's a hell of a lot better now than later since you've got it apart anyways... I'd have the stock rockers rebuilt and go with them...
Old 04-04-2009, 04:24 PM
Blamaro's Avatar
If your heads have bronze valve guides, don't run the stock rocker arms... get roller rockers to keep the bronze guides healthy.
Old 04-04-2009, 05:21 PM
djfury05's Avatar
Good advice is not just "oh since you got it apart already might as well"
a good answer should be based on functionality and stability issues with the setup.
I personally don't have the answer for you, just saying the first 2 replies are no help.
Old 04-04-2009, 05:54 PM
King Nothing's Avatar
replace em while your in there thats what i'm doin
Old 04-04-2009, 06:31 PM
Moderator
davered00ss's Avatar
What they are saying, and most everyone will agree is " it's cheap insurance to change the lifters while you have the heads off." You really do not want to get it all together and find out 6 months later you have a bad lifter. For $100 it just makes good sense.
No, you don't have to change them, just a good idea, just like changing your oil pump when you change the cam. LS7 lifters are the stock replacement now and are most popular now. They cost about $100 from any of the sponsors. I got mine from SDPC
As for rockers, stock are fine and there is no reason to change them.
Old 04-04-2009, 06:42 PM
SS#1230's Avatar
ive heard of guys getting a bad lifter soon after replacing them, and ive also heard of guys who havent changed them and never have a problem....
if you are going to change the lifters, get the LS2 trays too....
Old 04-04-2009, 11:14 PM
Z28SteveA4's Avatar
It just makes the most sense to replace them wth u new up to date ones even tho ur car has low miles. I mean there is nothing wrong with running the stock ones but if it was me and my car they would both be replaced just my .02
Quick Reply: Head/Cam Swap...will I need new lifters? Rockers?
